This system has worked fine for a year but recently if the solar gets the battery to 100 percent and it goes to float and its fine for a couple hours then the battery shuts down any ideas?
Is your battery communicating to the GX?
What is it reporting?
I would suggest you use the BYD app and see what it is reporting and if the BMS is unhappy, contact BYD support for assistance.
61 People are following this question.
