wolfbarnsolar avatar image
wolfbarnsolar asked
CCGX Configuration Multiplus 48/5000 1150 amps battery storage
Can I do this ???
If I want to automatically switch to a 240v Supply (to Charge concurrently with Solar) when the battery SOC drops to a defined level say 80% and then go back to inverter/solar when the battery voltage comes up to 95% SOC
while maintaining a generator input for high/excess current draw & charging when Mains is not available
can this be configured via CCGX or do i need VE configure & could someone instruct me on setting it up Please
CCGX Color Control
Peter Polz avatar image
Peter Polz answered ·
https://www.victronenergy.com/live/dc_coupling:using_bmv_soc_in_a_vebus_assistant_setup
You also can do it instead of BMV relais with CCGX generator relais/generator function.. so you can control it directly with CCGX
regards
Peter
wolfbarnsolar avatar image wolfbarnsolar commented ·
Thank you Peter that's interesting
I already use the ccgx gen/start/stop relay by SOC & High current Draw
but i have not had an Ac supply available until Now (currently OFF grid}
So now to Working out how to set up the AC part in the ccgx
wolfbarnsolar answered ·
Hi am getting myself a bit confused on Hub4 config Tree Meaning & how it should be set up (for Zero grid feed in) using AC1 input to Only charge the battery's
Am i correct with this Setup ?
Control without grid meter ON
inverter AC output ON
Phase compensation OFF
Minimum discharge SOC ? 80%
Limit charge Power 60amps
Max charge power 60 amps
Limit Discharge power ? Max discharge power
(is this not controlled by max current draw in battery AC load (auto start gen?)
Zero Feed in Active ON
Grid Setpoint ? 95% SOC
so when the battery SOC drops to a defined level say 80% and then go back to inverter/solar when the battery voltage comes up to 95% SOC
