pv-bauer avatar image
pv-bauer asked
cerbo, Digital Input settings, CO alert (carbon monoxide)?
In the Victron settings of the Digital Input I still found only the bullet point "CO2" alert,
but no "CO" Alert.
@ Victron is it possible to ad/ create an bullet point for carbon monoxide - "CO" as well in the cerbo digital input settings menu?
The facts behind both gases:
- carbon monoxide CO is a problem in houses, campers, boats.
Is a poisonous, flammable Gas, slightly less dense than air.
As a result of running engines generators or gas/ gasoline/ diesel heaters, stoves, barbecue (in closed rooms).
It's a product of a incomplete oxygen O and carbon C.
https://en.wikipedia.org/wiki/Carbon_monoxide
- carbon dioxide CO2 is normaly a problem in pubs, brewerys, vine cellars, or fire extinguishing systems.
CO2 is a natural gas in atmosphere.
CO2 is more dense than air.
The problem is a huge amount of CO2 that floods deep points eg. cellars or closed rooms and pushes the oxygen of the atmosphere out.
It's a product of a full oxidation of oxygen O2 and carbon C.
https://en.wikipedia.org/wiki/Carbon_dioxide
cerbo gx
Alexandra avatar image
Alexandra answered ·
@PV_Bauer
How are you setting the alarm?
Once you enable it you have to go back to the devices list and set it up further there.
Device list - co2 alarm - set up
Instructions are in the manual.
4 comments
pv-bauer avatar image pv-bauer commented ·
Hi Alexandra,
the digital input/ alarm works.
But I can't find a carbon monoxide alarm. So it is displayed as carbon dioxide CO2 alarm, not as carbon monoxide CO alarm.
derrick thomas avatar image derrick thomas pv-bauer commented ·
You can change the name in the device settings.
pv-bauer avatar image pv-bauer derrick thomas commented ·
Hello derrick thomas,
thank you for the hint. Meanwhile I found this workaround with the displayed name by myself too, to change the carbon dioxide alert to carbon monoxide alert.
rulexi avatar image rulexi pv-bauer commented ·
Please share your workaround.
