Robin avatar image
Robin asked
why can i not set absorption time in blue solar charge controller 100/50
i have set charge voltage and float voltage to rolls recommended voltages but i can not set the absorption time. i am in user defined setting. it should be 4.2 hrs and it is stuck on 6hrs.
any ideas please
MPPT Controllersbattery charging
Robin avatar image Robin commented ·
hi, thanks for info. sounds about right.
my firmware is v1.39 i would like to update to latest version but dont understand how to do this. all i can fined is how to update the invertas.
could you please advise how to update bluesolar via ve direct to usb
thanks for youre help
klim8skeptic avatar image klim8skeptic ♦ Robin commented ·
Hi Robin,
"could you please advise how to update bluesolar via ve direct to usb"
Read the manual fully. https://www.victronenergy.com/live/victronconnect:start
The VE direct>usb cable works fine on win10 and android, with VictronConnect.
klim8skeptic answered ·
Hi Robin,
Your bluesolar 100/50 will be running a firmware version with "adaptive" absorption time. See page 9 of the manual for details. https://www.victronenergy.com/upload/documents/Manual-BlueSolar-charge-controller-MPPT-100-30---100-50-EN-NL-FR-DE-ES-SE.pdf
Victron are working on the firmware to enable a fixed absorption time, but I don't think the latest firmware (v1.43) gives this. You will need a Bluetooth dongle or usb>ve direct cable to update the firmware. https://www.victronenergy.com/live/victronconnect:start
straightup avatar image
straightup answered ·
@Robin
The absorbtion management on Victron MPPT controllers has had problems across the board for months now. See here and here for a summary, and links to other people with similar problems, from the same root cause.
Victron has claimed to be working on/fixed these issues with firmware updates, but I first reported it in February and the problems still remains today.
In short- don't hold your breath for a solution.
Mark avatar image
Mark answered ·
Hi Robin,
Is your issue that your having trouble changing the absorption time in VictronConnect app from the 6h default?
Or that you have changed it and you believe that you are getting a different absorption time to what you have configured?
If your issue is configuring a different absorption time, could you post a screen image?
I have not used the VictronConnect app on PC (only on phone), but is there any '+' or '-' symbols and have you tried pressing them? If there is a scroll wheel have you tried to hold down your mouse button and drag the wheel up/down?
Upgrading the MPPT firmware won't help if your issue is actually configuring the absorption time.
But if you do want to update the FW to v1.42 ahead of the release into VictronConnect then you need to down load the correct FW file from Victron Professional;
https://professional.victronenergy.com/accounts/login/?next=/
Then follow the instructions in the VictronConnect manual for an update with self-supplied FW file (section 8.2);
MPPT Product Page
MPPT Error codes
