Eduard Bart avatar image
Eduard Bart asked
Sizing 36 Module a 430 kwp
Hallo miteinander,
ich habe vor mir 36 Module in 4 Strings zu je 9 Modulen aufs Dach installieren zu lassen.
Mit dem MPPT Calculator habe ich mir folgende Rechnung Erstellt:
https://mppt.victronenergy.com#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
Geplant sind 3 Multiplus-II 48/5000 und 3x Pylontech US5000
Jetzt bin ich wegen dem SmartSolar MPPT RS 450/200 leicht irritiert weil er aut Datenblatt 4000w pro Tracker und Gesamt nur 11520W DC Ladeleistung hat und ich ja 15480 kwp aufs Dach machen lasse. Ich werde außerdem drosselt er seine Ladeleistung ab 10°. Wird das später zu Problemen führen?
Ist meine Rechnung hier überhaupt Sinnvoll oder sollte ich das stringtechnisch anders aufs Dach machen lassen?
solar sizing
Eine gewisse Überdimensionierung der PV-Anlage ist durchaus üblich, meist 20-30%.
Ich würde aber sowieso nicht die komplette PV-Leistung über MPPTs auf der DC-Seite einbinden, sondern einen Teil auch über PV-Wechselrichter AC-seitig anschließen.
z.B. 2 Strings mit je 7 Modulen an einen 450/100 und den Rest (z.B. 2 Strings mit je 11 Modulen) auf einen 8kW PV-Wechselrichter.
4 comments
Eduard Bart avatar image Eduard Bart commented ·
Vielen lieben Dank für die super schnelle Antwort.
Was hat das für Vorteile?
Habe ich dann nicht Verluste, sollte ich die Batterie AC seitig laden müssen/wollen?
Matthias Lange - DE avatar image Matthias Lange - DE ♦ Eduard Bart commented ·
Wenn man eher wenige kleine Verbraucher hat und nicht Einspeisen will, ist DC vermutlich etwas besser.
Bei drei 5000er Multis und 15kWp PV gehe ich aber mal davon aus, das der Strombedarf nicht gerade gering ist.
Wenn z.B. eine Wallbox (oder ähnliche große Verbraucher wie Heizstäbe o.ä.) vorhanden/geplant ist, ist es effizienter diese direkt aus einem PV Wechselrichter zu bedienen als über die MultiPlus von der DC Seite.
Gleiches wenn man Überschuss einspeisen will, das ist über PV Wechselrichter deutlich effizienter.
Verluste hat man in beiden Richtungen, wobei man über PV Wechselrichter die Verluste 2x hat, daher muss man die gesamte Anlage und die geplante Nutzung kennen.
Eduard Bart avatar image Eduard Bart Matthias Lange - DE ♦ commented ·
Geplant ist nächstes Jahr ein Warmwasserspeicher der mit Überschuss PV geladen werden soll. ich hatte geplant das DC seitig zu tun. Wallbox und Wärmepumpe sind nicht ausgeschlossen aber noch nicht konkret in Planung.
die 5000er sind wegen "Luft nach oben" eingeplant. Theoretisch dürften 3000er langen.
phoenix-is-it avatar image phoenix-is-it Eduard Bart commented ·
Andersrum hast du Verluste beim Wandeln von DC in AC.
Die richtige Balance finden ist die Kunst.
(oder die Strings so flexibel bauen, dass sie auch später noch umgehängt werden können)
Eduard Bart answered ·
Ich habe mich jetzt ein wenig umgesehen, bei Fronius kann ich 2 der geplanten 4 Strings unterbringen. Würde in meinem Fall dann bedeuten 2 Strings zu je 9 an einem Symo 7.0-3-M bei einer Auslastung von 111% und die anderen beiden Strings auch zu je 9 an einen 450/100.
Verstehe ich das richtig? So kann ich dann im Bedarfsfall über AC-in der Multipluse die Batterie Laden.
holger Bleckwehl avatar image holger Bleckwehl commented ·
Für Wärmepumpe wird das nicht viel bringen ... im Winter gibt es kaum leistung vom Dach ;O)))
Nimm nen ordentlichen Fronius, dann kanst Du evtl. 2 x MP II 5000 einsparen...
aber wir kennen Deinen Hausverbrauch nicht ... muss man ein wenig planen und überlegen!
