darkfall avatar image
darkfall asked
MPPT RS 450/100 Start Up and Operating Range Question
Hey there folks,
I've got the MPPT RS 450/100 (the one with 2 trackers) and I'm curious about the start-up voltage and the operating voltage range.
  • Does anyone know if the start-up and operating range voltage is "per tracker" or, as a total of both strings?
The reason that I ask is that I've currently got 1 string going in, and it works fine. However, I have 2 more panels currently lying around (31.5 Vmp / 37.5 Voc) that I'd like to use on the second input of the MPPT. I don't want to add them to the existing string as the location would be different, so their power generation would also be quite different (shade would be an issue here, so I don't want them interfering). However, the voltage of this string would fall short of the start-up voltage (120v) and the operating voltage range (80 - 450V) of the MPPT.
My gut tells me that the start-up voltage is a total and the operating range is per tracker, however, I'd really like to verify this before I do anything.
MPPT ControllersMPPT SmartSolarmppt rs
nickdb avatar image
nickdb answered ·
It is per tracker.
New firmware 1.16 lowers the operating voltage lower limit to around 60V, the spec sheets are in the process of being updated.
darkfall avatar image darkfall commented ·
Great news about the firmware update info, thanks a lot for that!
I just wanted to verify something.
From what you wrote, I understand that the operating voltage is per tracker (thanks a lot for that verification). But, is the start-up voltage per tracker as well?
