Henry Pearson avatar image
Henry Pearson asked
10" touchscreen for Cerbo GX
I have a 10" touchscreen I plan on using for my Cerbo on my boat - is working well with a mouse but I'm having problems with the touchscreen.
I have been through the instructions here Generic touchscreen on Cerbo - Victron Community (victronenergy.com)
but when I come to run the calibrate function I get an error:
root@einstein:~# ts_calibrate
ts_setup: No such file or directory
It is ab "Akntzcs 10.1 inch from Amazon", I'm running firmware 3.30~17
Any ideas?
touchscreen
Henry Pearson avatar image Henry Pearson commented ·
@mvader (Victron Energy) any suggestions? Is this beta firmware related?
Al avatar image
Al answered ·
Maybe a bit late for you now, but I just use the touchscreen Amazon kindle fire 10" and fully Kiosk browser to view a mirror of the remote console with disabled hotkeys, so same view as my GX Touch. It works well, and works on Wi-Fi so you can walk around with it, but maybe a second or two lag when accessing menus.
Thanks, useful idea, but yes, screen already installed now.
I am going to install a Pi 5 and they were going to share the screen. But I could just use the web interface to access the cerbo
beagle avatar image
beagle answered ·
I run this:
Connect to your Cerbo via SSH.
Run the following commands...
opkg update
opkg install tslib-calibrate
Enable headless mode...
touch /etc/venus/headless
reboot
fbset -xres 1024 -yres 600
ts_calibrate
Now go to the screen and do the actual calibration on the screen.
Once calibration is done disable headless mode...
rm /etc/venus/headless
reboot
But you probably trtied that.
Leo
@Beagle thanks I had tried that but will give it another go next week. Someone on FB pointed out, I had been hitting enter between the 2 lines of fbset..... and ts_calibrate
That then produced the error, will try it together on one line
