I was curious what the difference between these modes are and which would I would use to connect my BMV-712 so that I could shut it off when it reaches a certain SOC.
I'd assume relay mode is the one I want but I am not quite sure.
What product are you asking about?
I can't believe I forgot to include the product I was talking about. My apologizes. But my question was referring to the Victron Battery Protect.
I figured out that you can trip the relay (turning it on/off) with the BMV with default settings and works with the other modes.
I changed the title for you, now it's more clear :)
from the manual:
So relay mode or buzzer/led mode is the way the device alarms (buzzer or relay)
Li-ion mode the unit switches based on the control input only, no alarm output.
9 People are following this question.
