I have connected 2 MPPTs with the origninal Victron cable to a Raspberry.
When I restart the system, I always have the problem, in Node-Red the MPPTs are lost...
Is there a way to avoid it?
It looks like you are running an older version of the GX firmware (checked your sites and all run v2.9x). That means that the node-red-contrib-victron version you run is from before version v1.4.25 (https://github.com/victronenergy/node-red-contrib-victron/releases/tag/v1.4.25), where this problem was solved.
My advice is to update the firmware to the latest official release (which includes v1.5.x of node-red-contrib-victron).
113 People are following this question.
