dmq avatar image
dmq asked
Multiplus 12/500 no light not functioning
Dear forum
my Multiplus 12/500 stopped working. I do not know why (it was running, no manual changes).
When I provide the MP with 13.5V DC from a power supply I can see, that it uses 1.6W. I can measure the voltage between the positive input terminal and the transformator (13.3V DC). But there is no light and I can not see the MP through USB / MK3 interface. No other parts are connected to it.
Does someone has an idea / clue?
Thank you very much in advance,
Christian
Multiplus-IIfault
dmq avatar image
dmq answered ·
Does someone know if this device just has one exchangeable fuse (the one which sits directly at the positive 12V DC input terminal)?
I checked the capacitors (just looking on the surface etc.) - I can't see some obvious damage.
Could it be that the flash storage of the microcontroller is damaged?
kevgermany avatar image
kevgermany answered ·
Sorry, but you need to contact the dealer and probably return it for service/repair.
dmq avatar image
dmq answered ·
Thank you. Unfortunately it is out of warranty. I live in germany: does somone know a good repair shop / contact?
5 comments
It may be cheaper to replace it.
Use the where to buy link on the victron site. It will show suppliers in the area that are repair centers.
They're only serviceable by Victron. Green Akku have been good to me. Empfehlenswert.
https://greenakku.de/
dmq avatar image dmq kevgermany ♦♦ commented ·
Ok thank you both. I know greenakku but never had an order there. Sad that I need to replace the whole unit. The unit is only 5 years old and in production use for about 1 year. Don't understand what happened. I was in hope that Victron Inverters would be quiet robust and that parts can be repaired. Not good but maybe I should just leave it behind me.
kevgermany avatar image kevgermany ♦♦ dmq commented ·
Check the serial number. It starts HQ, followed by year and week. Warranty is 5 years. Talk to the vendor, you may be lucky.
Thanks. Probably no luck - nearly 6 years ;-)
MultiPlus-II Product page
MultiPlus-II Manual
Multiplus-II GX Online Manual
MultiPlus-II 230V Datasheet
VE.Bus Error codes
Faults with Victron equipment are best discussed directly with your dealer - this can be formalised with this support request form.
