foxfrance avatar image
foxfrance asked
BMV-700 Indicates current draw while charging
i have connecties bmv 700 To a single agm battery. The monitor keeps telling that about 200 watts is drawn from battery, although all obvious powersources are disconnected. Battery percentage drops although the battery is full or charging. Charging connections om shunt does mot help. Resetting also not
BMV Battery Monitorpower meter
That sounds bad.
Post a photo of the shunt and battery please.
Mark avatar image
Mark answered ·
Upon initial review it seems that the shunt or PCB board is somehow connected in reverse.
Check that the 'battery' side of the shunt is ONLY connected to the battery and that ALL other connection's for charge sources and loads are connected to other side marked 'load/charger'.
Victron BMV battery monitors product page
