Ondřej Ludvík avatar image
Ondřej Ludvík asked
Can't connect EV charging station NS to Cerbo GX device
Hello, i Can't connect EV charging station NS to Cerbo GX device. Both devices are connected to the same network. GX device has the latest software and Modbus TCP is enable. If I set the charging station to automatically search for the GX device, it will find its IP address, but if I search on GX in modbus TCP/UPD devices nothing appears.
ev charging station
Lucian Popescu (Victron Energy Staff) avatar image
Lucian Popescu (Victron Energy Staff) answered ·
You can manually add the ip of the evcs in the gx/settings/modbustcp devices. Make sure the whitelist is disabled on the evcs side.
