does a working rs485/usb node exist on ned red ?
Thx
Depending on what you are trying to accomplish, you may be able to use the 'custom' input and output nodes in the victron node pallet.
would like to communicate to a USB/RS485 adapter for a Pace BMS Modus connection.
the adapter seams to work, with a pallette - contrib-modbus node I do get infos from the battery, but 99% wrong.
maybe time to start all over.
no? not a good RS485 node out there?
tested with raspi iobroker modbus adapter, works fine.
86 People are following this question.
