4711austria avatar image
4711austria asked
Node-Red RS485 Modbus ?
Hi
would like to read out a rs485 modbus device, but installing of node-red-contrib-modbus just fails?
2024-03-01T14:37:13.361Z Installieren : node-red-contrib-serial-modbus 0.0.11
2024-03-01T14:36:57.793Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --production --engine-strict node-red-contrib-serial-modbus@0.0.11
2024-03-01T14:37:03.944Z [err] npm
2024-03-01T14:37:03.949Z [err]
2024-03-01T14:37:03.950Z [err] WARN
2024-03-01T14:37:03.951Z [err] config production Use `--omit=dev` instead.
2024-03-01T14:38:44.079Z Installieren : node-red-contrib-modbus 5.30.0
2024-03-01T14:39:01.937Z [err] npm ERR! code 1
2024-03-01T14:39:01.937Z [err] npm ERR! path /data/home/nodered/.node-red/node_modules/@serialport/bindings
2024-03-01T14:39:01.937Z [err] npm ERR! command failed
2024-03-01T14:39:01.937Z [err] npm ERR! command sh -c prebuild-install --tag-prefix @serialport/bindings@ || node-gyp rebuild
2024-03-01T14:39:01.937Z [err] npm ERR! make: Entering directory '/data/home/nodered/.node-red/node_modules/@serialport/bindings/build'
2024-03-01T14:39:01.937Z [err] npm ERR!   CXX(target) Release/obj.target/bindings/src/serialport.o
2024-03-01T14:39:01.937Z [err] npm ERR! make: Leaving directory '/data/home/nodered/.node-red/node_modules/@serialport/bindings/build'
2024-03-01T14:39:01.937Z [err] npm ERR! gyp info it worked if it ends with ok
2024-03-01T14:39:01.937Z [err] npm ERR! gyp info using node-gyp@9.4.0
2024-03-01T14:39:01.937Z [err] npm ERR! gyp info using node@18.18.0 | linux | arm
2024-03-01T14:39:01.937Z [err] npm ERR! gyp info find Python using Python version 3.8.18 found at "/usr/bin/python3"
2024-03-01T14:39:01.937Z [err] npm ERR! gyp http GET https://nodejs.org/download/release/v18.18.0/node-v18.18.0-headers.tar.gz
2024-03-01T14:39:01.937Z [err] npm ERR! gyp http 200 https://nodejs.org/download/release/v18.18.0/node-v18.18.0-headers.tar.gz
2024-03-01T14:39:01.937Z [err] npm ERR! gyp http GET https://nodejs.org/download/release/v18.18.0/SHASUMS256.txt
2024-03-01T14:39:01.937Z [err] npm ERR! gyp http 200 https://nodejs.org/download/release/v18.18.0/SHASUMS256.txt
2024-03-01T14:39:01.937Z [err] npm ERR! gyp info spawn /usr/bin/python3
2024-03-01T14:39:01.937Z [err] npm ERR! gyp info spawn args [
2024-03-01T14:39:01.937Z [err] npm ERR! gyp info spawn args   '/usr/lib/node_modules/npm/node_modules/node-gyp/gyp/gyp_main.py',
2024-03-01T14:39:01.937Z [err] npm ERR! gyp info spawn args   'binding.gyp',
2024-03-01T14:39:01.937Z [err] npm ERR! gyp info spawn args   '-f',
2024-03-01T14:39:01.937Z [err] npm ERR! gyp info spawn args   'make',
2024-03-01T14:39:01.937Z [err] npm ERR! gyp info spawn args   '-I',
2024-03-01T14:39:01.937Z [err] npm ERR! gyp info spawn args   '/data/home/nodered/.node-red/node_modules/@serialport/bindings/build/config.gypi',
2024-03-01T14:39:01.937Z [err] npm ERR! gyp info spawn args   '/usr/lib/node_modules/npm/node_modules/node-gyp/addon.gypi',
2024-03-01T14:39:01.937Z [err] npm ERR! gyp info spawn args   '/data/home/nodered/.cache/node-gyp/18.18.0/include/node/common.gypi',
2024-03-01T14:39:01.937Z [err] npm ERR! gyp info spawn args   '-Dlibrary=shared_library',
2024-03-01T14:39:01.937Z [err] npm ERR! gyp info spawn args   '-Dvisibility=default',
2024-03-01T14:39:01.937Z [err] npm ERR! gyp info spawn args   '-Dnode_root_dir=/data/home/nodered/.cache/node-gyp/18.18.0',
2024-03-01T14:39:01.937Z [err] npm ERR! gyp info spawn args   '-Dnode_gyp_dir=/usr/lib/node_modules/npm/node_modules/node-gyp',
2024-03-01T14:39:01.937Z [err] npm ERR! gyp info spawn args   '-Dnode_lib_file=/data/home/nodered/.cache/node-gyp/18.18.0/<(target_arch)/node.lib',
2024-03-01T14:39:01.937Z [err] npm ERR! gyp info spawn args   '-Dmodule_root_dir=/data/home/nodered/.node-red/node_modules/@serialport/bindings',
2024-03-01T14:39:01.937Z [err] npm ERR! gyp info spawn args   '-Dnode_engine=v8',
2024-03-01T14:39:01.937Z [err] npm ERR! gyp info spawn args   '--depth=.',
2024-03-01T14:39:01.937Z [err] npm ERR! gyp info spawn args   '--no-parallel',
2024-03-01T14:39:01.937Z [err] npm ERR! gyp info spawn args   '--generator-output',
2024-03-01T14:39:01.937Z [err] npm ERR! gyp info spawn args   'build',
2024-03-01T14:39:01.937Z [err] npm ERR! gyp info spawn args   '-Goutput_dir=.'
2024-03-01T14:39:01.937Z [err] npm ERR! gyp info spawn args ]
2024-03-01T14:39:01.937Z [err] npm ERR! gyp info spawn make
2024-03-01T14:39:01.937Z [err] npm ERR! gyp info spawn args [ 'BUILDTYPE=Release', '-C', 'build' ]
2024-03-01T14:39:01.937Z [err] npm ERR! ../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Open(Nan::NAN_METHOD_ARGS_TYPE)':
2024-03-01T14:39:01.937Z [err] npm ERR! ../src/serialport.cpp:78:69: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]
2024-03-01T14:39:01.937Z [err] npm ERR!    78 |   uv_queue_work(uv_default_loop(), req, EIO_Open, (uv_after_work_cb)EIO_AfterOpen);
2024-03-01T14:39:01.937Z [err] npm ERR!       |        ^~~~~~~~~~~~~
2024-03-01T14:39:01.989Z [err] npm ERR! ../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Update(Nan::NAN_METHOD_ARGS_TYPE)':
2024-03-01T14:39:01.989Z [err] npm ERR! ../src/serialport.cpp:135:71: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]
2024-03-01T14:39:01.989Z [err] npm ERR!   135 |   uv_queue_work(uv_default_loop(), req, EIO_Update, (uv_after_work_cb)EIO_AfterUpdate);
2024-03-01T14:39:01.989Z [err] npm ERR!       |        ^~~~~~~~~~~~~~~
2024-03-01T14:39:01.989Z [err] npm ERR! ../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Close(Nan::NAN_METHOD_ARGS_TYPE)':
2024-03-01T14:39:01.989Z [err] npm ERR! ../src/serialport.cpp:175:70: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]
2024-03-01T14:39:01.989Z [err] npm ERR!   175 |   uv_queue_work(uv_default_loop(), req, EIO_Close, (uv_after_work_cb)EIO_AfterClose);
2024-03-01T14:39:01.989Z [err] npm ERR! ../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Flush(Nan::NAN_METHOD_ARGS_TYPE)':
2024-03-01T14:39:01.989Z [err] npm ERR! ../src/serialport.cpp:215:70: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]
2024-03-01T14:39:01.989Z [err] npm ERR!   215 |   uv_queue_work(uv_default_loop(), req, EIO_Flush, (uv_after_work_cb)EIO_AfterFlush);
2024-03-01T14:39:01.989Z [err] npm ERR! ../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Set(Nan::NAN_METHOD_ARGS_TYPE)':
2024-03-01T14:39:01.989Z [err] npm ERR! ../src/serialport.cpp:270:68: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]
2024-03-01T14:39:01.989Z [err] npm ERR!   270 |   uv_queue_work(uv_default_loop(), req, EIO_Set, (uv_after_work_cb)EIO_AfterSet);
2024-03-01T14:39:01.989Z [err] npm ERR! ../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Get(Nan::NAN_METHOD_ARGS_TYPE)':
2024-03-01T14:39:01.989Z [err] npm ERR! ../src/serialport.cpp:314:68: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]
2024-03-01T14:39:01.989Z [err] npm ERR!   314 |   uv_queue_work(uv_default_loop(), req, EIO_Get, (uv_after_work_cb)EIO_AfterGet);
2024-03-01T14:39:01.989Z [err] npm ERR! ../src/serialport.cpp: In function 'void EIO_AfterGet(uv_work_t*)':
2024-03-01T14:39:01.989Z [err] npm ERR! ../src/serialport.cpp:329:96: error: no matching function for call to 'v8::Object::Set(v8::Local<v8::String>, Nan::imp::FactoryBase<v8::Boolean>::return_t)'
2024-03-01T14:39:01.989Z [err] npm ERR!   329 |     results->Set(Nan::New<v8::String>("cts").ToLocalChecked(), Nan::New<v8::Boolean>(data->cts));
2024-03-01T14:39:01.989Z [err] npm ERR! In file included from /data/home/nodered/.cache/node-gyp/18.18.0/include/node/v8-array-buffer.h:13,
2024-03-01T14:39:01.989Z [err] npm ERR!                  from /data/home/nodered/.cache/node-gyp/18.18.0/include/node/v8.h:24,
2024-03-01T14:39:01.989Z [err] npm ERR!                  from /data/home/nodered/.cache/node-gyp/18.18.0/include/node/node.h:73,
2024-03-01T14:39:01.989Z [err] npm ERR!                  from ../../../nan/nan.h:62,
2024-03-01T14:39:01.989Z [err] npm ERR!                  from ../src/./serialport.h:6,
2024-03-01T14:39:01.989Z [err] npm ERR!                  from ../src/serialport.cpp:1:
2024-03-01T14:39:01.989Z [err] npm ERR! /data/home/nodered/.cache/node-gyp/18.18.0/include/node/v8-object.h:244:37: note: candidate: 'v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, v8::Local<v8::Value>, v8::Local<v8::Value>)'
2024-03-01T14:39:01.989Z [err] npm ERR!   244 |   V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context,
2024-03-01T14:39:01.989Z [err] npm ERR! /data/home/nodered/.cache/node-gyp/18.18.0/include/node/v8-object.h:244:37: note:   candidate expects 3 arguments, 2 provided
2024-03-01T14:39:01.989Z [err] npm ERR! /data/home/nodered/.cache/node-gyp/18.18.0/include/node/v8-object.h:247:37: note: candidate: 'v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, uint32_t, v8::Local<v8::Value>)'
2024-03-01T14:39:01.989Z [err] npm ERR!   247 |   V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context, uint32_t index,
2024-03-01T14:39:01.989Z [err] npm ERR! /data/home/nodered/.cache/node-gyp/18.18.0/include/node/v8-object.h:247:37: note:   candidate expects 3 arguments, 2 provided
2024-03-01T14:39:01.989Z [err] npm ERR! ../src/serialport.cpp:330:96: error: no matching function for call to 'v8::Object::Set(v8::Local<v8::String>, Nan::imp::FactoryBase<v8::Boolean>::return_t)'
2024-03-01T14:39:01.989Z [err] npm ERR!   330 |     results->Set(Nan::New<v8::String>("dsr").ToLocalChecked(), Nan::New<v8::Boolean>(data->dsr));
2024-03-01T14:39:01.989Z [err] npm ERR! ../src/serialport.cpp:331:96: error: no matching function for call to 'v8::Object::Set(v8::Local<v8::String>, Nan::imp::FactoryBase<v8::Boolean>::return_t)'
2024-03-01T14:39:01.989Z [err] npm ERR!   331 |     results->Set(Nan::New<v8::String>("dcd").ToLocalChecked(), Nan::New<v8::Boolean>(data->dcd));
2024-03-01T14:39:02.081Z [err] npm ERR! /data/home/nodered/.cache/node-gyp/18.18.0/include/node/v8-object.h:244:37: note: candidate: 'v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, v8::Local<v8::Value>, v8::Local<v8::Value>)'
2024-03-01T14:39:02.081Z [err] npm ERR!   244 |   V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context,
2024-03-01T14:39:02.081Z [err] npm ERR!       |                                     ^~~
2024-03-01T14:39:02.081Z [err] npm ERR! /data/home/nodered/.cache/node-gyp/18.18.0/include/node/v8-object.h:244:37: note:   candidate expects 3 arguments, 2 provided
2024-03-01T14:39:02.081Z [err] npm ERR! /data/home/nodered/.cache/node-gyp/18.18.0/include/node/v8-object.h:247:37: note: candidate: 'v8::Maybe<bool> v8::Object::Set(v8::Local<v8::Context>, uint32_t, v8::Local<v8::Value>)'
2024-03-01T14:39:02.081Z [err] npm ERR!   247 |   V8_WARN_UNUSED_RESULT Maybe<bool> Set(Local<Context> context, uint32_t index,
2024-03-01T14:39:02.081Z [err] npm ERR! /data/home/nodered/.cache/node-gyp/18.18.0/include/node/v8-object.h:247:37: note:   candidate expects 3 arguments, 2 provided
2024-03-01T14:39:02.081Z [err] npm ERR! ../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE GetBaudRate(Nan::NAN_METHOD_ARGS_TYPE)':
2024-03-01T14:39:02.081Z [err] npm ERR! ../src/serialport.cpp:363:76: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]
2024-03-01T14:39:02.081Z [err] npm ERR!   363 |   uv_queue_work(uv_default_loop(), req, EIO_GetBaudRate, (uv_after_work_cb)EIO_AfterGetBaudRate);
2024-03-01T14:39:02.081Z [err] npm ERR!       |        ^~~~~~~~~~~~~~~~~~~~
2024-03-01T14:39:02.081Z [err] npm ERR! ../src/serialport.cpp: In function 'void EIO_AfterGetBaudRate(uv_work_t*)':
2024-03-01T14:39:02.081Z [err] npm ERR! ../src/serialport.cpp:378:106: error: no matching function for call to 'v8::Object::Set(v8::Local<v8::String>, Nan::imp::IntegerFactory<v8::Integer>::return_t)'
2024-03-01T14:39:02.081Z [err] npm ERR!   378 |     results->Set(Nan::New<v8::String>("baudRate").ToLocalChecked(), Nan::New<v8::Integer>(data->baudRate));
2024-03-01T14:39:02.081Z [err] npm ERR! In file included from /data/home/nodered/.cache/node-gyp/18.18.0/include/node/v8-array-buffer.h:13,
2024-03-01T14:39:02.081Z [err] npm ERR!                  from /data/home/nodered/.cache/node-gyp/18.18.0/include/node/v8.h:24,
2024-03-01T14:39:02.081Z [err] npm ERR!                  from /data/home/nodered/.cache/node-gyp/18.18.0/include/node/node.h:73,
2024-03-01T14:39:02.081Z [err] npm ERR!                  from ../../../nan/nan.h:62,
2024-03-01T14:39:02.081Z [err] npm ERR!                  from ../src/./serialport.h:6,
2024-03-01T14:39:02.081Z [err] npm ERR!                  from ../src/serialport.cpp:1:
2024-03-01T14:39:02.081Z [err] npm ERR! ../src/serialport.cpp: In function 'Nan::NAN_METHOD_RETURN_TYPE Drain(Nan::NAN_METHOD_ARGS_TYPE)':
2024-03-01T14:39:02.081Z [err] npm ERR! ../src/serialport.cpp:409:70: warning: cast between incompatible function types from 'void (*)(uv_work_t*)' {aka 'void (*)(uv_work_s*)'} to 'uv_after_work_cb' {aka 'void (*)(uv_work_s*, int)'} [-Wcast-function-type]
2024-03-01T14:39:02.081Z [err] npm ERR!   409 |   uv_queue_work(uv_default_loop(), req, EIO_Drain, (uv_after_work_cb)EIO_AfterDrain);
2024-03-01T14:39:02.081Z [err] npm ERR! ../src/serialport.cpp: At global scope:
2024-03-01T14:39:02.081Z [err] npm ERR! ../src/serialport.cpp:430:28: warning: unnecessary parentheses in declaration of 'ToParityEnum' [-Wparentheses]
2024-03-01T14:39:02.081Z [err] npm ERR!   430 | SerialPortParity NAN_INLINE(ToParityEnum(const v8::Local<v8::String>& v8str)) {
2024-03-01T14:39:02.081Z [err] npm ERR! ../src/serialport.cpp:449:30: warning: unnecessary parentheses in declaration of 'ToStopBitEnum' [-Wparentheses]
2024-03-01T14:39:02.081Z [err] npm ERR!   449 | SerialPortStopBits NAN_INLINE(ToStopBitEnum(double stopBits)) {
2024-03-01T14:39:02.081Z [err] npm ERR! In file included from ../../../nan/nan.h:62,
2024-03-01T14:39:02.081Z [err] npm ERR! /data/home/nodered/.cache/node-gyp/18.18.0/include/node/node.h:1014:43: warning: cast between incompatible function types from 'void (*)(Nan::ADDON_REGISTER_FUNCTION_ARGS_TYPE)' {aka 'void (*)(v8::Local<v8::Object>)'} to 'node::addon_register_func' {aka 'void (*)(v8::Local<v8::Object>, v8::Local<v8::Value>, void*)'} [-Wcast-function-type]
2024-03-01T14:39:02.081Z [err] npm ERR!  1014 |       (node::addon_register_func) (regfunc),                          \
2024-03-01T14:39:02.081Z [err] npm ERR! /data/home/nodered/.cache/node-gyp/18.18.0/include/node/node.h:1048:3: note: in expansion of macro 'NODE_MODULE_X'
2024-03-01T14:39:02.081Z [err] npm ERR!  1048 |   NODE_MODULE_X(modname, regfunc, NULL, 0)  // NOLINT (readability/null_usage)
2024-03-01T14:39:02.081Z [err] npm ERR! ../src/serialport.cpp:483:1: note: in expansion of macro 'NODE_MODULE'
2024-03-01T14:39:02.081Z [err] npm ERR!   483 | NODE_MODULE(serialport, init);
2024-03-01T14:39:02.081Z [err] npm ERR! make: *** [bindings.target.mk:110: Release/obj.target/bindings/src/serialport.o] Error 1
2024-03-01T14:39:02.081Z [err] npm ERR! gyp ERR! build error
2024-03-01T14:39:02.081Z [err] npm ERR! gyp ERR! stack Error: `make` failed with exit code: 2
2024-03-01T14:39:02.081Z [err] npm ERR! gyp ERR! stack     at ChildProcess.onExit (/usr/lib/node_modules/npm/node_modules/node-gyp/lib/build.js:203:23)
2024-03-01T14:39:02.081Z [err] npm ERR! gyp ERR! stack     at ChildProcess.emit (node:events:517:28)
2024-03-01T14:39:02.081Z [err] npm ERR! gyp ERR! stack     at ChildProcess._handle.onexit (node:internal/child_process:292:12)
2024-03-01T14:39:02.081Z [err] npm ERR! gyp ERR! System Linux 5.10.109-venus-15
2024-03-01T14:39:02.081Z [err] npm ERR! gyp ERR! command "/usr/bin/node" "/usr/lib/node_modules/npm/node_modules/node-gyp/bin/node-gyp.js" "rebuild"
2024-03-01T14:39:02.081Z [err] npm ERR! gyp ERR! cwd /data/home/nodered/.node-red/node_modules/@serialport/bindings
2024-03-01T14:39:02.081Z [err] npm ERR! gyp ERR! node -v v18.18.0
2024-03-01T14:39:02.081Z [err] npm ERR! gyp ERR! node-gyp -v v9.4.0
2024-03-01T14:39:02.081Z [err] npm ERR! gyp ERR! not ok
2024-03-01T14:39:02.160Z [err]
2024-03-01T14:39:02.160Z [err] npm ERR! A complete log of this run can be found in: /data/home/nodered/.npm/_logs/2024-03-01T14_37_03_338Z-debug-0.log
2024-03-01T14:39:02.252Z rc=1
pls hlp. thx!
cerbo gx
