rocco avatar image
rocco asked
Victron Cerbo GX generator start/stop help
I am asking for help with the settings for the Cerbo GX regarding the generator start/stop function. The problem is as follows: In the settings, I have the generator start/stop function enabled based on two parameters, namely Battery condition and AC load. When the generator is switched on due to AC load, after the consumption falls below the set limit, the generator is not switched off, but continues to operate. VRM displays: Running for: Battery condition. Why is this so and how would I set this that Cerbo will turning off the generator immediately after the consumption drops below the set limit?
generator auto startremote startlocalsettings
Cerbo GX - Generator auto start/stop
Automatic Generator Start/ Stop [PDF]
Automatic Generator Start/ Stop [Online]
Which relay and control to use?
How to wire generators with a three wire interface.
