puven avatar image
puven asked
Multi rs solar AC in problem
Having trouble getting ac in to work. Even asked for help from the company purchased from and still not worked it out. Inverter sees power coming in but relay not activating. Is it a setting problem or is relay bridge on the little plug on the inverter.
If someone who has it working could lay out the steps in simple 1.2.3.4 steps that would be really appreciated. I’m going around in circles.
Thanks
Multi RS
Hi @Puven
The first settings I would check are:
Disable UPS mode
Disable conditional AC input connection
I am not sure what you mean by the relay plug. It should have nothing to do with with connecting the AC supply to the AC input terminals.
puven avatar image
puven answered ·
Hi Guy
Have tried everything. Including resetting multiple times. Something is wrong with the AC IN relay because settings aren't changing anything. I went through it with the retailer I purchased from and we tried various options and I now have put in a warranty claim.
Relay "plug bridge". it was a suggestion for the terminal on the multiplus that might need to be bridged, but nobody has needed to do that in the past to make the AC In work so I didn't try it. It didn't make sense to me anyway and I was worried about shorting something out.
When plugged into a battery, AC out works, but the AC In just wont play.
Hi @Puven,
Could you please take a screenshot of this screen in VictronConnect while the AC input is connected?
