Hi guys
what do I do now Ive run out of be direct and used both usb (via ve direc to usb). Im looking at adding a 4th mppt to the ccgx device.
is there a way to connect a 5th device. USB hub or ?
thanks
Hi guys
thanks
I have a similar situation and found that this powered USB hub works with the Venus GX connecting 5 MPPT's - 2 via ve.direct and the other 3 USB. 4 Port Black USB 2.0 Hub - USB-A Hubs | USB Hubs | StarTech.com United Kingdom
I’d like to keep clear of a powered solution. Has anyone tried a simple y splitter?
You may buy the VE.CAN version (and use network-cables)
69 People are following this question.
