An old install (10+ years), I have connected recently the temp probe via T-Sence in the Quattro.
Is it a plug and play only, or should I do some configuration in the CCGX?
Thank you for the reply.
Ok, should I do also a "calibration" on the Quattro (the same as I did on the Multi earlier today i.e. Superuser)?
Also, this would mean that the quattro will use this temp value during the charge cycle?
In the inverter itself (since it was designed for there) no there doesn't need to be a calibration.
I still check though.
It is used for temp compensated charging in lead acid systems and low cut off for lithium.
Victron temperature sensor disambiguation table - which product supports which sensor
43 People are following this question.
