frankvw avatar image
frankvw asked
What USB interface cable for a multiplus?
Just to make sure I'm not ordering the wrong kit: I have a Multiplus 24/800/16 that I need to connect my laptop to in order to set it up beyond what I can do with the DIP switches. Do I need the MK3 USB interface cable or the VE.Direct USB interface cable?
Tnx!
multiplus ve.busmk3-usb
djsmiley avatar image
djsmiley answered ·
MK3. Multiplus has no ve direct ports.
VE direct is for (eg) the smaller MPPTs and shunts.
pwfarnell avatar image
pwfarnell answered ·
You need the mk3 USB interface cable.
mjs500 avatar image
mjs500 answered ·
mk3 USB interface cable and Rj45 Utp cable
sharpener avatar image
sharpener answered ·
AFAIR you can set up (nearly) everything via VRM which saves buying any cables other than the RJ45 to connect to your router, which presumably you have got already.
4 comments
pwfarnell avatar image pwfarnell commented ·
Do you still need a Venus OS device though to go through VRM rather than connecting the inverter direct to the router.
sharpener avatar image sharpener pwfarnell commented ·
I imagine so, not faced with that problem, my Multi II GX has it built in.
Others will know for sure what config you need.
kevgermany avatar image kevgermany ♦♦ pwfarnell commented ·
VRM is only through GX device.
Not all, but don't ask me what's missing. I just know there are some settings I can only get to through the MK3 usb interface.
