unico avatar image
unico asked
High output signal after disconnect?
I have the BP220 battery protect used for loads. Current setting is Mode C. I have an inverter that does not have remote off. Instead I want to use a latching relay (not a normal relay as I don’t want the constant draw).
Question: how can I get a signal high from the BP after disconnect such that I can disconnect the inverter? In Mode C the alarm output does not work (which is kinda stupid).
I prefer to keep it in Mode C as I have an external BMS with ATD signal.
Battery Protect
