eliott avatar image
eliott asked
modifying OverviewMobile.qml to display remaining distance
Hi!
I already did some modifications to OverviewMobile.qml to get values about storm warning that I populate from dbus from a python script that gets data from a json service.
I thought I have a basic understanding of how Victron Qt thing works, however, I am stuck getting a basic value from the service dbus the same way it works on my own custom namespace.
This is my code:
                 VBusItem {
                                bind: Utils.path("com.victronenergy.system","/DC/Battery/TimeToGo")
If I want to display the value (localtimetogo.value), it always gives me undefined, when displaying text (localtimetogo.text) gives me "--"
What am I doing wrong?
thanks
Venus OS
Ole Saether avatar image Ole Saether commented ·
I have done some qml coding but I believe your code above is incomplete. Show us the complete code or how you are trying to display the value.
Ole Saether answered ·
Have you tried something like this?
MbItemValue {
    description: qsTr("Time to go")
    item.bind: Utils.path("com.victronenergy.system","/DC/Battery/TimeToGo")
4 comments
eliott avatar image eliott commented ·
I need to do calculations with that number, speed (m/s) * timetogo (secs) / 1000.
The speed value I can get with
VBusItem {
                                bind: Utils.path("com.victronenergy.gps","/Speed")
But the same logic does not work with TimeToGo
This is the relevant code:
                    values: [
                                TileText {
                                        text: getDist()
                                        visible: true
                                        VBusItem {
                                        VBusItem {
                                        function getDist()
                                                return localspeed.value * localtimetogo.value / 1000
any help is really appreciated
eliott avatar image eliott eliott commented ·
@osaether can you spot the error please?
Finally, I found the typo, thanks @osaether for trying to help
it is
Utils.path("com.victronenergy.system","/Dc/Battery/TimeToGo")
as opposed to:
