Hi I was just wondering if I can connect a touch screen for the Rasberry Pie to a genuine Victron Cerbo GX and will it work ok or can it be done with some set up?
The "official Raspberry PI 7" touchscreen" can not be connected to Cerbo.
SOME HDMI displays have been successfully connected to Cerbo.
As I said, SOME HDMI touchscreens work. SOME DO NOT. There are no settings in Cerbo.
Obviously, I don't want to get into a discussion about your mods, as this is not the place for it, but I would be stupid having accidentally found you not to ask you a question that I have spent some time trying to solve with no luck, so I will risk it :-). In Package manager when trying to install VeCanSetup, it says it has to be done from the command line, How can I do this in a real Cerbo? Is there some instructions somewhere please?
I apologise if I have overstepped the mark, I am 72 and new to this stuff, Would I use putty? Bob
I have been thinking a lot about how best to display information that non-technical users can interpret and the gauges are (in my opinion) are the right approach. No numbers at all on the overview screens !!!!!!
Victron's gui-v2 is a complete rethink of the user interface and is a huge step in the right direction. Focus is on providing clean, uncluttered displays that non-technical users can interpret. While it is not ready for real use it is worth a look to see the direction Victron is headed.Kevin, so I have logged in with putty and got no such file?
"login as: root
Last login: Sat Feb 10 22:29:47 2024 from ***********
root@einstein:~# /data/VeCanSetup/setup
--- starting setup script v3.9
creating package options directory /data/setupOptions/VeCanSetup
cat: can't open '/data/VeCanSetup/FileSets/fileList*': No such file or directory"
I can see the files are in/data/VeCanSetup, but there is no FileSets folder that the script asks for?
Make PackageManager shows v6.4 is available as a GitHub version for SetupHelper. If -- is shown, check your internet connection to the GX device.
You can also force a GitHub version refresh by turning off automatic downloads and turning it back on again.
Hmm still not installing Kevin.
"root@einstein:~# /data/VeCanSetup/setup
VeCanSetup adds CANbus ports to the Venus OS system
Cerbo GX includes 2 CANbus ports
an unlimited number of USB ports may be configured
Available actions:
Install and activate (i)
Uninstall (u) and restores all files to stock
Quit (q) without further action
Display setup log (s) outputs the last 100 lines of the log
Choose an action from the list above: i
no CANbus definitions found ?
Victron has instructions on how to access the command line:
well, you seem to be the guy to ask,
if you know and could kindly share? what screen does work natively with the cerbo gx?
Would this one work?
UCTRONICS for Raspberry Pi Screen 7 Inch IPS Touchscreen with Prop Stand, 1024×600
It connects through hdmi and usb and has the same resolution as the touch 7"
im just getting into all this and keep hearing about guimods, so thank you for your contribution!
Edit: guess i shouldve kept reading as someone linked to one that will work. which is a 7" 800x480
I found the same exact screen but in a 1024x600 version, should work right?
https://www.amazon.com/gp/product/B01GDMDFZA/ref=ox_sc_act_title_1?smid=A3UAI31N6IJM2&psc=1
Anyway, back to the display. The one I purchased was the Electrow 7" HDMI , when I connect it to the Cerbo it looked promising, I got a Blue Victron splash screen saying it was starting and then it displayed the Cerbo display. problem is though the size is only about a third the size of the screen and the touch doesn't work correctly because of that.
I don't know if there is anything I can do now? there are no settings to change the picture size anywhere, on the displays menu I can only change the aspect ratio, any ideas anyone please?
When I touch anything I get something else, looking closely I can see a very very tiny mouse pointer and it is always tracking about an inch from my finger tip and I cannot move it below a third of the screen. Is this a problem with the screen or is it a problem with the Venus software for the Pie? Is there anything I can do to correct it please?
Also there was a Victron Firmware update 3.2 and now Gui mods won't work saying there isn't a version for 3.2. Thank you Kevin .Bob
A few people have tried HDMI displays on Cerbo with random success. It seems to depend on the display. Efforts to make a display that does not work function have not been successful, so there really is nothing I can do to automate a generic HDMI setup script for Cerbo. Sorry.
Your options are to use the GX touch with Cerbo or to use other displays with a Raspberry PI running Venus OS.
I use a 11" hdmi screen (shared with computer onboard) and a mouse very successfully on my cerbo. It doesn't like gui 2.0 as the cursor doesn't show but that is in beta so hoping they fix that before full release.
I have purchased another screen and this one works perfectly with the Cerbo-GX straight out of the box, it's this one.
https://www.amazon.co.uk/dp/B0BHJ26B32?psc=1&ref=ppx_yo2ov_dt_b_product_details
I'm sure there may be others, would be nice if there was a sort of central repository where everyone could list screens they have bought that work with no modifications. Anyway this one works perfectly
awesome thanks!
i found this same one on the US amazon for anyone looking
7" 800x480
but im a stickler for resolution and i found the same exact screen for only $5 more but in 1240x600 which is the same native resolution as the victron touch 7"
i wonder this would work the same?
The WaveShare 7" touch screens work out the box on the cerbo gx.
dimming won't work, but the screensaver (switching off after a set period) will with a few changes to a couple of config files, only downside is those files need to be changed each time you do a firmware update, but no big deal.
Look at Kevin King's answer here for the code changes:
https://community.victronenergy.com/questions/93218/generic-touchscreen-on-cerbo.html?childToView=268848#answer-268848
86 People are following this question.
