sheppy avatar image
sheppy asked
EasySolar 5000 Charge Query from Genset
Hi. Our System is current setup so that the genset can either charge the batteries and run the house or just run the house. I'm wondering if it can be set via the controller interface to only charge the batteries so that the house would always be drawing from the batteries and not the genset?
EasySolar All-in-One
JohnC avatar image
JohnC answered ·
Hi @Sheppy
No, that's not possible. The Multiplus uses common circuitry for charging and inverting, so can't do both at the same time.
If you're worried about generator quality power getting to household appliances?.. The Multi is often called 'picky' for rejecting gensets, and there's some adjustments available, but usually satisfactory using default values.
sheppy avatar image sheppy commented ·
Thanks. Do you think it might be possible to charge the battery pack directly from a genset using a different charger? if so, would you have any recommendations?
JohnC avatar image JohnC ♦ sheppy commented ·
@Sheppy
It's certainly possible. I only recommend Victron kit, but that's just me. Someone else might have other ideas or preferences, but it's hard to say anything without knowing a few details on what you're looking to do. A battery Voltage would help too.. :)
