Can a Cerbo GX be used to control a 120v air conditioner?
Depends does the air con.
Some when power is cut, their default is off and you need to hit a the remote or button to switch on again.
We would need to know more about the unit and if you are savvy with wiring and contactors etc.
I would not run the circuit directly through the cerbo but use the cerbo to drive an external relay.
81 People are following this question.
