rangerpeterson avatar image
Loosing power
I recently updated my travel trailers power system. I installed 4 100w solar panels wired in series. Those run down to a Victron 100/30 charge controller and Victron Battery monitor. They are connected to a Battle Born 100w Lithium battery and a Victron Multiplus 12/3000w inverter which is tied into the circuit breaker.
My problem is a constant 6-6.3 amp draw on the system. I have no idea where it is coming from. I have tried shutting down all circut breakers and fuses and it dosent stop the draw. If I disconnect the battery disconnect between the batter and inverter the power loss stops. Any ideas about where a 6 amp power loss could be coming from?
Help
wkirby avatar image
wkirby answered ·
Where are you measuring this 6A draw, what part of the circuit and what device is reporting it?
