sim-1 avatar image
sim-1 asked
"Virtual" Device, Data Fed via ModbusTCP/MQTT
I have a SmartSolar PV controller connected to Venus Pi via VE.direct. I also have a control system that has MODBUS TCP client coded and I successfully communicate with Venus to read battery volts. This system also activates supplemental battery charger which provides data via proprietary protocol.
Goal: Consolidate the energy used by battery charger in one place with the data of the SmartSolar (PV power and load usage).
Is there a way to add a virtual device in Venus, preferably with holding (read and write) MODBUS registers that I can "feed" from my control system? I don't think my control system has a module to be MODBUS master, but if there was would that work?
Alternative could be via MQTT, but I am yeat to experiment with that.
Venus OS
matt1309 avatar image
matt1309 answered Ā·
Hi @Sim
I think this is what you're after:
howto add a driver to Venus Ā· victronenergy/venus Wiki Ā· GitHub
Here's an example script: velib_python/dbusdummyservice.py at master Ā· victronenergy/velib_python Ā· GitHub
I believe if you use a existing dbus path from below link that it setups up MQTT topics correctly for you.
dbus Ā· victronenergy/venus Wiki Ā· GitHub
I've never tried ModbusTCP but i imagine it's handled the same. Adding completely custom device might be a bit more involved, but i think it does cover that in the "how to add a driver to venus" link i shared above however I've never tried that.
I have used this for method for getting an old radio oil tank sensor into venus. I have a raspberry pi capture the radio frequency of the oil sensor then send it via mqtt into venus os which has a virtual tank sensor script installed using the method described above. The only change i needed to make to dummy script was service name change to
com.victronenergy.tank.tty01
