same question for BMS.can cable, routing along with DC-charge cable?
Should it be avoided because of signal errors or something similar?
thank you
thank you
Probably. We don't see problems reported here.
Your CAN cable should also be ok as even the basic ones are twisted pair and most are shielded these days.
I agree with kev, however if you can avoid doing so then that would be better. It's sort of suck and see if you get issues then look at it then. Also note that the ve. Direct us not twisted pair Nd you could get issues of lost devices from time to time if the cables are long.
41 People are following this question.
