I've got a Sony IJ1004C and 2 IJ1001M.
Does the CAN communication work with Cerbo GX?
How is the cable connection setup?
The sony side is subd 9 pin and the cerbo gx RJ45.
Thanks
Thanks
It is not on the official supported list.
For the CAN to work you need to identify the CAN H and CAN L and GND on the Sony side. The Victron ones are here.
You can make up a cable and try, you might win especially if they use a bms from a known battery.
There is a thread with guys working with other BMSs if you are interested.
Thanx Alexandra!
I can't write protocols, but I hope the communication will work on the pylontech US5000 protocol for example. Can I test it with a cerbo GX, without other devices (multiplus-II) connected?
29 People are following this question.
