shop6 avatar image
shop6 asked
Why do DBUS requests to Cerbo GX via python/paramiko/ssh take so long (0.5 sec/call)?
Getting this (attributes)
/Dc/Battery/Soc
/Yield/System
/Ac/L1/Energy/Forward
/Ac/L2/Energy/Forward
/System/MinCellVoltage
/System/MaxCellVoltage
/System/MinCellTemperature
/System/MaxCellTemperature
/System/MinVoltageCellId
/System/MaxVoltageCellId
/System/MinTemperatureCellId
/System/MaxTemperatureCellId
needs more than 10 seconds.
Is there a faster way to read out the current data from the Victron system?
cerbo gxModbus TCP
@shop6 Moved to modifications space.
Kevin Windrem avatar image
Kevin Windrem answered ·
The command line dbus calls do take a while but there is another call: dbus-send that takes far less time per call.
Look here:
https://github.com/victronenergy/venus/wiki/commandline---development
shop6 avatar image
shop6 answered ·
There is a faster alternative: modbustcp calls by pymodbus, see below.
Unfortunately, not all values readable via dbus are available, e.g. /Yield/System, and the values supplied via modbustcp, e.g. /System/MinCellVoltage:1290, are less precise.
Modified sample code from https://community.victronenergy.com/questions/190594/need-help-with-python-modbus-queery.html, tested with pymodbus-3.6.8 on Python 3.9.2, RaspberryPiCM4, CerboGX v3:
from pymodbus.constants import Endian
from pymodbus.client import ModbusTcpClient as ModbusClient
from pymodbus.payload import BinaryPayloadDecoder
BattID = 225
ip = "192.168.2.38"
client = ModbusClient(ip, port='502')
def modbus_register(address, slave):
    msg     = client.read_holding_registers(address, slave=slave)
    decoder = BinaryPayloadDecoder.fromRegisters(msg.registers, byteorder=Endian.BIG)
    msg     = decoder.decode_16bit_int()
    return msg
BatterySOC  = modbus_register(266, BattID) / 10
print(f"BatterySOC {BatterySOC}")
outsourcedguru avatar image outsourcedguru commented ·
Rather than using ip, you might just hard-code in " venus.local".
