shock avatar image
shock asked
Multiplus II 48/5000 freq problem
Hello I have a problem with frequency generation by Victron, namely when the voltage comes from the grid, the frequency is 50 hz, when I switch to off grid the frequency jumps to 51.5 and cuts off my production from the solar edge installation. Does anyone have an idea what could be wrong in the logs? nothing shows any errors
Multiplus-IIfrequency
shock avatar image
shock answered ·
Nobody knows? :) there is one more variable, this happens when the victrons disconnect from the grid due to too high voltage, if I disconnect the grid manually at this point, the photovoltaic installation starts working normally and does not increase the frequency anymore
shock avatar image
shock answered ·
the problem is still unresolved, there is one variable that I have observed, if only the grid is manually operated with the switch, then the victron works as it should, there is no problem with the frequency, it is still 50hz and it turns on the solaredge installations
kevgermany avatar image
kevgermany answered ·
Tricky one. I've asked for some technical help.
shock avatar image shock commented ·
Thank you i need help no issue for that :(
And you help me?
shock avatar image
shock answered ·
hello still no issue for that problem nobody dont know what doo to help me?
daza avatar image
daza answered ·
Cover some basics please The array connected to AC1 out. The size of the array what you are using to monitor the output of the array to integrate with victron systems?
