alfredogutierrez avatar image
alfredogutierrez asked
Configure Multiplus 2 Frequency Shift with Sunny Boy 5KW (sma)
Hello everybody.
I installed actually one multiplus 2 5000 48v 70a with lifepo4 batteries (18s) and BMS JK.
I have one Sunny Boy 5kw installed in ACOUT with the multiplus 2. All the loads the multiplus 2 are in AC-OUT.
I have a question about the configuration frequency shift for the correct working multiplus 2 with Sunny boy.
The screen for configure Sunny boy frequency shift (default) is this:
screenshot-20210907-222147.jpgWhat configuration I have to configure to multiplus 2 ESS?? This??
Thanks in advance.
Best Regards.
Multiplus-IIfrequency
Anil Ghatikar avatar image
Anil Ghatikar answered ·
Hello the setting you should look at is Fack which is +1 ( start regulation) +2 Stop power production - the +- 5 HZ is the frequencySB-OffGrid-TI-en-42 highlight.pdf variation allowed not for regulation. may be attached document can help
MultiPlus-II Product page
MultiPlus-II Manual
MultiPlus-II 230V Datasheet
VE.Bus Error codes
