tommorganrolfe avatar image
tommorganrolfe asked
Battery Protect 12/24 Cutting out
Hi
I have a Battery Protect 12/24 used to switch the load output from a SmartSolar 75/15. It works fine normally. However when the SmartSolar is getting lots of sun on switch on it cuts out - but not with a normal E code but instead there are 2 flashing zeros. The battery Protect has the default programming. Is there any way around this?
Many thanks. Tom
Battery Protect
