David Gould avatar image
David Gould asked
CCGX relay for generator
Can I reverse the relay login on a CCGX? My generator needs open cct to switch on
CCGX Color Control
Paul B avatar image
Paul B answered ·
You would need to attached another relay to it to achieve the reversing option ie a NC/NO relay
wkirby avatar image
wkirby answered ·
There is no option to reverse the relay logic for a generator.
You'll need to use the relay output to drive another relay with NC contacts so that the circuit will open when the internal relay contacts close.
David Gould answered ·
Thanks, thought that was the case but was worth asking
