You need to resize a window for synchronization to resume.
Maybe @Guy Stewart (Victron Community Manager) should take a look.
The video shows the problem.
Now a second problem for a few days. The "System - PV Yield" data from the globallink 520 which accumulates the mppt is no longer present in VRM?!
https://vrm.victronenergy.com/installation/391178/share/d913f9f1
The PV yield missing is a seperate issue that has also been reported - "System - PV Yield" Gateway widget disappeared.
Hi @Pablooo,
Thanks for the bug report, the VRM team have found and fixed the issue.
Could you please check its now working as expected?
41 People are following this question.
