andsg77 avatar image
andsg77 asked
HELP VICTRON SYSTEM + EKRANO GX
I'm preparing this system to control 2 different Battery Pack.
I've some questions:
  1. I want to connect all the system to an Ekrano GX but I've only 3 port VE.DIRECT. I need to connect 2 x MPPT + 2 x SHUNT + 2 x ORION XS for a total of 6 VE.DIRECT things.
  2. Everything is linked with a Battery Switch except the MPPTs that are directly connected to the Battery so the Solar Pannel will always charge. This is correct?
  3. What do you think about the schema? Is ok? I want to have always under control the 2 battery pack that I've on board.screenshot-2024-01-21-alle-195524.png
ekrano gx
VE Direct can be combined using VE Direct to USB adapters. If this results in too many USB connections, a USB hub can be used, preferable a powered one.
I'm not sure, however, that this setup will work. 2 smart shunts as battery monitors my not be supported. Must check the manual. You may need to use 2 Ekranos.
Ekrano GX product page.
Ekrano GX online manual
Ekrano GX datasheet
