HI there. I've been using multiples 24v 3000kva 240ac. It was working fine until I connected ve bus with RC 45 cable. Now the inverter turns on and off. Also can't see dongle in victron connect. Any ideas much appreciated.
Have you tried other cables? Are the cables fully wired, some don't have all the connectors wired.
Otherwise a wiring diagram and photos would help.
39 People are following this question.
