gndubi avatar image
gndubi asked
Effect of low load power Factor on Inverter-Generator Integration
One of the loads connected to a 3 phase 15kVa Quattro inverters has a low load power factor (as low as 0.5). When this load is connected the integrated diesel generator's output is ignored by the inverters. However the load appears not to affect the generator output (values are within threshold). How can we solve this?
powerassist
JohnC avatar image
JohnC answered ·
Hi G. I'm guessing somewhat with such a low PF (and 3 phase). But a start point would be here:
https://www.victronenergy.com/live/multiplus_faq
The ultimate 'Weak AC Input' function I need to use myself.. I've felt your pain, just with the generator and no PF considerations.
