Cerbo GX keeps stop communications --- can I reset the Cerbo GX remotely
If there is no contact then no there is no way to communicate with it.
However for nmnext time it is online you can set under the VRM portal in settings an automatic reboot on contact and set your preferred time.
39 People are following this question.
