I have the Victron MultiPlus 250/60. How can I remotely control it over the web? I see there is the Victron Color Control GX, but are there cheaper options? I would setup a LTE Arduino connection to broadcast wifi.
The Cerbo S. The colour control is out of date.
There is no Cerbo S in the overview of current communication centres. When googling, I find a Victron Cerbo-S GX, the little brother of the GX. Is that/those the ones you mean?
Ahh, the links I added all vanished as a comment. I meant this overview: https://www.victronenergy.no/communication-centres
We usually drop the GX suffix from Cerbo and others. So yes, the Cerbo-S is what @Alexandra recommended.
If you have a small system and can find one, the Colour Control is a still a good unit, even though it's superceded. Main limitation is the slow CPU.
If you're computer literate, you can use the Victron Venus OS on a Raspberry Pi as your GX. Details in the modifications space. Be aware there is no Victron support, just the users in modifications.
https://www.victronenergy.com/communication-centres/cerbo-gx
The CCGX does not have inbuilt WiFi you will need a separate dongle for that if you go that route.
42 People are following this question.
