Josep morancho avatar image
Josep morancho asked
Ultrasonic TS1 level sensor & Cerbo GX
I want to test if the ultrasonic TS1 level sensor ( https://www.svb24.com/en/bepmarine-all-purpose-tank-sensor-ts1.html ) works with my Cerbo GX and the first problem that I have is that the TS1 level sensor has 3 cables and the tank level connection in the Cerbo has only 2 inputs.
How do I have to connect the 3 TS1 cables to the Cerbo?
Thanks
tank monitor
gordon-thoms avatar image
gordon-thoms answered ·
Hi Josep,
Did you received, or found a solution for that problem?
I have the same one. I‘m trying to connect my TS1 sensors with my Cerbo gx but I have only fixed resistence values.
I have no idea anymore.
jeremyb avatar image
jeremyb answered ·
I found the TS1 does not work as a resistive sender with the Cerbo as the TS1 is not a true resistive device.
However, by programming the TS1 instead as a voltage sender and connecting them to a GX Tank 140 (which connects to the Cerbo by USB) they work fine. I have three setup this way.
Hi Jeremyb,
I think it works now. I connected the red wire to Battery, the black one to ground and into the Cerbo and the green wire also into the Cerbo. I adjusted the resistance, if tank full und empty manually. The quantity indication is fluctuating on my display but I‘m fine now. I guess the Cerbo GX Tank could be a good sollution in the future. I will observe the indication in my vacation.
