I have 2 mulitplus-ii gx in parallel. Using mppt to charge lifepo4 batteries which are using daly bms. The daly bms gives the inverters the SOC.
I have an assistant installed so that the inverter doesn't use the grid.
Question:
how do I make the assistant use the grid if bms cuts off without it staying for 1sec where all my devices would get offed.
![17052962247926025351320353428620.jpg](/storage/attachments/68726-17052962247926025351320353428620.jpg)
