beertje avatar image
beertje asked
Tank 140 sensor
Hi, will a Wema S5 gevers (2 wire, blue/brown 0-10V) work on a GX Tank 140? If I connected to channel 1 (Vout and In) nothing happens. If i connected it to Vout and grnd, and move the swimmer up and down then the voltage changes between 0 and 10V.
If this doesnt work on the GX Tank140, which type/kind do i need?
thx
sensorgx 140
pwfarnell avatar image pwfarnell commented ·
Are you sure this is a sensor with voltage output as I thought the Wema S5 were resistance and could connect direct to the Cerbo GX. 2 wire senders are normally resistance.
A voltage sender needs 3 wires, ground, positive supply and signal wire.
Check your documentation.
beertje avatar image beertje pwfarnell commented ·
ahhh, thank u. then i have to buy a other one...
