I have on board a Multiplus Compact 12/2000/80-30 230V. It came with firmware 1908132. Which version can i upgrade to with VEFlash? I will use my MK3 USB.
Best regards
Per Christian Stenstadvold
Best regards
Thank you for your answer. The charger came with the boat that I bought in 2022. I think this is from about 2017 as I was told but I'm not sure.
1908209 this is the current latest version for that unit,
Remotely Update VE.Direct Firmware
VictronConnect manual / Firmware updates
Updating a Victron Smart Solar MPPT Charge Controller with Victron Connect
VictronConnect configuration guide for VE.Bus products - Firmware Updates
48 People are following this question.
