When the battery power of the house exceeds 4KW, will the AC input assist the battery with extra power, so that the battery stays below 4kW?
If you have ESS installed it can be set up like that.
A combination of having the right input current limit and limit inverter power.
If it rejects grid however it is all on the battery. It is important to size correctly.
40 People are following this question.
