I have a Hyundai HY4500SEi generator I would like to control from the Cerbo GX. The Generator does not have an ATS plug but is remotely controlled from a key fob with start and stop buttons.
Have anyone done this or have an idea on how to do it?
you will need to purchase a gen auto-start unit ie a Mebay DC-30 unit then wire that into your gen and then install the mebay trigger to the cerbos relay number one.
There are other units out there as well. and if you search this forum for generator autostart you should fine a basic wiring diagram
38 People are following this question.
