duto69 avatar image
duto69 asked
MPPT 250/100 rev2 high temperature?
My system start cut off power from MPPT. When I check alarm logs, it is empty - no alarms log found. MPPT go 5 time during two minutes to OFF state. More detail info in pictures.
When I check temperature of MPPT with termal camera Flir, maximum temperature was around 45 celsius.
It happen yeasterday and today at same time.
DVCC is off
devices in system:
MultiPlus-II 48/5000/70-48
BMV-712 smart
MPPT 250/100
200Ah gel battery
https://imgur.com/a/Ot7yf2d
MPPT Controllerstemperature
wkirby avatar image
wkirby answered ·
What is the configuration of your PV? Was there enough PV Voltage to maintain charge?
What about the remote on/off terminal, is that circuit closed, is the jumper in place?
duto69 avatar image duto69 commented ·
PV - 20 pcs of Q-cell 330Wp. There are 4 paraller with 5 in series.
PV voltage jump at top 185V and current fall down to 0A when power is cut off.
Remote on/off - the jumper is in place.
MPPT Product Page
MPPT Error codes
