Bert Hennephof avatar image
Bert Hennephof asked
Control panel for EasySolar II GX
Some time ago I had difficulties connecting from VRM and Remote console to connect to my EasySolar-II-GX-24/3000/70 (with a LiFePO4 Smart 25,6V 200Ah and a VE.Bus BMS V2). Meanwhile the problem has been solved, but still I am puzzled about possibility to connect a physical control panel.
The "color control" seems to be a possibility, but my dealer says the EasySolar is not compatible with that (although I doubt that). On the Victron site I see the "color control" will be replaced by the "Ekrano GX", but that is a too extensive (and too expensive) solution for me.What about the cheaper "GX Touch 50" or "CANvu GX"?
In the end I just would like to have a "backup" control option, that connects directly to the EasySolar. Which option would work?
EasySolar All-in-Oneekrano gx
