Hello
How it can be removed a Pv Inverter (yyyy) from PV Inverters that doesn't exist.
Hello
What happens if you (re)scan for PV inverters?
What happens if you reboot the Cerbo?
Happens even with a standard, unmodded, Cerbo firmware?
From programming point of view, this happens when, for clear, you fill a zone with a certain character (usually 0) and then, for showing purposes, you verify that the character buffer contains the same init fill value. If not, it means that in that zone is a valid information and you show it.
In your case, the secondary inverter zone may have been filled with invalid characters from a glitch sometime, and then, the printing routines believe that there is stored a valid information there and show it to you.
But this is just a supposition from my side and I may be far removed from the truth...
I suppose you could try to contact the developers and ask them to check and tell you what you can do.
Please, @Guy Stewart (Victron Community Manager) , @Thiemo van Engelen (Victron Energy staff) , can you help him? Thank you in advance!
77 People are following this question.
