pennysr avatar image
pennysr asked
Parasitic Draw - Victron Battery Protect?
Curious, would a battery protect from Victron help with a parasitic draw? At least prevent it from getting too low to become a problem?
I was watching a video on it and there are presets but the highest voltage on the 12v presets was 12v and at 12v, a battery is basically dead. Is that accurate? Or is it dumbed down for people that don't know 12v is extremely low?
I have a stereo system on a vehicle that doesn't come with one, I have a 24/12 converter that doesn't have a remote on/off so I just put a disconnect switch on the negative, it turns off the radio but somehow my battery still drains after a week or two, the batteries are fine.
Any advice?
Thanks
Battery Protect
With the Smart BatteryProtect you can setup the thresholds freely but the device itself also has a small current draw.
Do you have the disconnect switch before the radio or before the converter?
The converter will also have a small current draw even if there is nothing connected to it..
pennysr avatar image pennysr commented ·
I have a cutoff switch on the negative side before the converter, I was told thats better because of no sparking. When I flip the switch, all the electronics go off but this only seemed to be happening since I installed the converter.
Does it matter if the negative is connected to the battery vs the vehicles shunt?
