rampage avatar image
rampage asked
Programming ess assistant on system whit multiple inverters(multi's)
i have an exsisting system based on an multiplus II whit ess assistant.
i expanded the system whit an other multiplus and set up the fases.
now i can't seem to get the menu for setting up assistance.
not by downloading file from vrm or whit an bus mk3 adaptor, both relaunch me to set up fases again.
any idea's?
Assistants
Alexandra avatar image
Alexandra answered ·
@rampage
Are you trying to access the inverter settings through ve bus configurator?
rampage answered ·
Yes, tried both downloading file from vrm and whit the bus converter. Works perfectly when I originally installed the single unit now whit 2 in parallel, I can only get phase configuration.
You need to look at the training then. You right click and select ve configure multi in the ve bus configurator.
